2000 Silverado compatible with 2004?
Old Oct 27, 2022 | 1:13 PM
Ryan38's Avatar
Default 2000 Silverado compatible with 2004?
My 2000 Silverado needs a new rear end and I have the opportunity to purchase a 2004 Chevy with a bad transmission. Are the parts compatible? Transmission swap or rear end swap works for me. Just need a running truck. Thanks in advance. The 2000 is a 4x4 but not sure if the 2004 is.
Old Jul 21, 2025 | 11:15 AM
Hulk40187's Avatar
If im not mistaken it’s 99-06 that are all basically mechanically the same 4l60e and just make sure the rear end has the same amount of diff cover bolts and it should be 3:73 ratio or 4:10 you can check your glove box for code GTA(3:73) for example, i just did my rear end it was pretty easy. If it’s not 4x4 you will need the part that goes between the transmission and drive shaft I forgot the name of it.
Wes_S
Aug 11, 2016 12:03 PM
kitty666
May 12, 2016 2:53 PM
nmokry82
Dec 25, 2011 12:42 PM
adnildell
Sep 7, 2010 6:22 PM
redpeppers
Dec 7, 2005 12:55 AM
