2000 Silverado problems - help needed
Old Jan 23, 2006 | 7:17 PM
Soulcrusher's Avatar
Default 2000 Silverado problems - help needed
Hello all,
The story begins last year when the truck just died. It ended up that the ignition coil wire shorted out. New wires/plugs and it seemed to run so-so with occasional missing. It has gotten bad now. I have new wires, plugs, cap and rotor and fuel filter. It seems to only be bad when it's cold or wet. On nice warm or dry days, it runs pretty good and after running for a while during the day and the engine compartment warms up, it runs well too. Any ideas where to go next.
Thanks,
John
Old Feb 20, 2006 | 10:54 PM
Default RE: 2000 Silverado problems - help needed
OK, Lots of lookers but no input. Here's an update. It seems to idle great, but as soon as I touch the throttle, it starts to miss a bit. If I try to keep it right at the same speed (like around 55 on the hiway for instance) it will buck and kick and miss, but if I lay the wood to it at wide open throttle it works fine. I took a chance and dropped a new throttle posit sensor in because it seemed to be related to throttle position, but that didn't help. Anyone? Anyone? .......
Old Feb 25, 2006 | 2:40 AM
jhop's Avatar
hi
my name is justin and i have a 02 silverado that seemed to do the same thing i changed the mass air flow sensor and put a k&n intake and have not had a prblem sence
Old Feb 25, 2006 | 9:21 AM
hawk265's Avatar
I have 1999 2500 that had a similar problem just recently. I changed, wires, plugs and mass air flow sensor and none worked. Finally I figured out that it was the fuel pressure regulator.
turbotim23
May 8, 2015 4:54 PM
georgiasdad
Jul 31, 2012 4:16 AM
WIBackpacker
Apr 8, 2012 4:51 PM
jpm1207
Aug 25, 2010 8:05 AM
Zayde
Jun 26, 2008 7:36 PM
