2001 Silverado parking brake
I have been having trouble with the parking brake on my Silverado Sportside with the manual transmission and 6 cyl engine. It currently has 151000 miles on it and it is my daily driver. I have had the parking brake recall done by the Chevy dealer. I have replaced the cables 3 times as well. I use the parking brake every time I drive the vehicle so I wouldn't think it would rust up from dis-use. Now it is time for inspection and they are not working again. When I checked this morning I found that one cable, the longer one on the right side is broken again. Both cable attachment yokes are frozen to the brake actuator, I suspected that this might occur as when I replaced the cables the last time I had to file the yoke because the Delco cable yokes wouldn't fit the actuator. One side was ok but the other side wasn't. I remember a similar problem other times when changing the cables.
GM now has a parking brake kit, P/N 19178787 which costs $140 for each side. It includes all the parts including the shoes and new backing plate. To install the kit it looks like I will need to open the differential so that the axle shafts can be pulled out. It will still need cables.
My question is that since this is a kit, is it a re-designed assembly that will allow the parking brake to operate like it should for a long time, or will I have to keep replacing cables every year even though I use it all the time?
There are many vehicles with 4 wheel disc brakes that don't have the problems these trucks have with the parking brake, so I hope GM has made an improvement.
Thanks for any help with this issue.
Steve Sykes
2001 Silverado
2003 Malibu
Lifelong GM customer!
Steve Sykes
2001 Silverado
2003 Malibu
jg33
January 3rd, 2021 3:17 PM
Bobby
August 16th, 2009 4:02 PM
Greg O
September 8th, 2006 2:21 AM
