2003 Silverado Driver Door Panel Removal
Good Morning,
I am looking for some assistance in removing the driver's side door panelon my 2003 Silverado 1500 Extended cab.Where I am having trouble is removing the power windows and locks switch panel...the bottom side, pull handle side I got to pop up release a spring, but the top side, hinge side is very tight. Does that also pop up or is there a screw that is hidden. If I could get some over all instructions to remove the panel this would be great. But as of now am stuck trying ot remove the switch panel. Thanks
RE: 2003 Silverado Driver Door Panel Removal
Remove the two screws. One is under the grab handle and one is under the manual lock. Hold the panel and have someone pull the connections to the electric. There is a screw from the back of the panel into the switch plate on some years. that's probably the problem.
neto1978
December 30th, 2012 6:48 AM
rjdesaint
January 13th, 2010 10:18 PM
neisy13
April 11th, 2008 10:36 AM
MountainMan71
November 15th, 2007 1:25 AM
