2004 coolant
Old September 30th, 2012 | 10:53 AM
GM Fixer's Avatar
Default 2004 coolant
2004 silverado what kind and mixture of antifreeze 5.3 l should i put in
Old September 30th, 2012 | 11:07 AM
cleveland63b's Avatar
50/50 dexcool
Old September 30th, 2012 | 11:13 AM
GM Fixer's Avatar
I heard that dexcool can eat at the gaskets head and intake what do you think customer service?
Old September 30th, 2012 | 1:08 PM
kevinkpk's Avatar
I don't think it's an issue with the 5.3. I have a 2000 5.3 with dexcool. Had it flushed two years ago, and replaced with dexcool. I think the problem was the 5.7 plastic turkey tray in the intake, plastic gaskets, what next.......... I hope someone with more experience can confirm this.
Old September 30th, 2012 | 3:46 PM
as long as you maintain and flush it you'll be fine, any coolant will eat gaskets if its not serviced
Old September 30th, 2012 | 10:19 PM
Fishinfooleric10@aol.com's Avatar
They say dexcool is the only thing you are supposed to put in the GMs especially because with having the aluminum block the regular coolant will cause corrosion. I would not use anything else other than dexcool.
Old October 1st, 2012 | 5:00 PM
dirtsurferus's Avatar
Dexcool is the only thing they say to use in GM's. Either use Dexcool or go to a shop who can flush/fill with Safety-Kleen's Khameleon Antifreeze.
Old October 1st, 2012 | 9:23 PM
birdie's Avatar
don't trucks come with owners manuals anymore
Old October 2nd, 2012 | 5:37 AM
grumpychevy's Avatar
Yes, they do but that would require someone to put down their computer and actually read print. Seems it's easier to have someone else do your work for you.
Old October 2nd, 2012 | 11:44 PM
if everyone went by the owners manual the aftermarket and performance worlds wouldnt exist
Quick Reply: 2004 coolant
