Notices
Old August 10th, 2015, 12:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
2005 Chevy Silverado
Old November 27th, 2018, 11:47 AM
  #21
abohaczek80's Avatar
Default 4WD wont disengage
When I have the TREC fuse in my truck, my truck locks into 4wd and I cant get it into 2wd. When I pull the fuse out, it stays in 2wd.
Anybody have any ideas on what could be causing this?
Old November 28th, 2018, 10:30 PM
  #22
Dave Himbert's Avatar
Originally Posted by tina75
I had the codes checked on the truck and it is reading code B0100 for the service air bag light. The mechanic said I need to replace the frontal sensor and they want to charge $185.00 for this. Any ideas?
Also, they said I need a whole new radio assembly, cost $380.00.
The front sensor is easy to replace - I did mine several years ago! Check out 1AAuto or You tube it. There are two. To find out which one is defective, unplug and switch sides both sensors. I can't remember what transpires so that you know which one is defective, hence checking out the above sites. I also bought the sensor very cheap on Ebay or 1AAuto.
The radio... I would pull the negative cable off the battery, wait for 5 minutes, then hook it back up. Then try the CD changer. Sometimes this works to reset the radio electronics. If not, try LKQ if you have a newer truck, they may have one that is cheap but still working fine.
Good luck!
chevymnz71
September 9th, 2009 9:04 PM
wmjackson15
April 24th, 2009 3:03 PM
shadyg07
February 27th, 2009 7:04 PM
hfb1957
November 21st, 2008 4:26 PM
sgiles
August 2nd, 2008 9:28 PM
Quick Reply: 2005 Chevy Silverado
