2009 Silverado Door Locks Manual Bypass
Old Oct 31, 2015 | 12:15 PM
coloradosilver's Avatar
Default 2009 Silverado Door Locks Manual Bypass
Hi all,
Am new here. I searched around for a how-to on making a manual bypass switch to disable our automatic door locks. Couldn't find anything other than DIC instructions and didn't want to fiddle around with that every time we want to turn the locks off. Also, I'm not sure this truck has the lock configuration option in the DIC...
Our 2009 is a work truck, some days we can end up with the locks cycling hundreds of times (slight exaggeration). I wanted something simple, just a switch that would turn the things OFF. Figured out a way to bypass and switch a couple of fuses in the dashboard fuse panel. Best method I could come up with uses a couple of things called "Fuse Buddy" to make a bypass harness. Seems to be working well. I've got my own blog so I published the how-to over there. I wasn't clear on if the forum rules allow posting of links to things like my article, so here goes. If I'm out of line please remove.
https://www.wildsnow.com/18431/silve...isable-bypass/
