Last edit by: IB Advertising
Browse all: Wheels and Tires
- Chevrolet Silverado GMT800, GMT900, K2XX Why is Truck Vibrating
Guide to diagnose trouble and recommended solutions.
2014 silverado with a bad vibration
#151
Greetings all, I just bought a 2014 Z71 4X4. This is one of the smoothest trucks I've driven, but then, it only has 300 miles on it. I hope I don't have any of these issues! I haven't read all posts on this subject, But I'm wondering if there are any issues with drive shafts and balancing?
#152
I also have a 2014 silverado 4x4 with 7100 miles, I changed the rims and tires and noticed a really bad shake at 65 mph on up gets worse towards 70 mph I took it to the dealer, service writer and mechanic both drove truck and both agreed their was a problem. Their answer to the problem was aftermarket wheels and tires, so I put the truck back to stock took truck back in to the dealer and what do you know same issue. Still no fix this is my 5th brand new silverado and this is the first one im not happy with. I really hope GM steps up to correct this issue AND STOPS BLAMING AFTERMARKET PARTS.
#153
They would have to rule out factory rims and tire just the same as aftermarket. The problem is that gm will not pay for warranty testing of YOUR aftermarket parts. Why should the dealer work for free to test your parts. The annoyance you feel at the dealer for the tire related portion of this is your own fault.
the proper sequence to rule out vibrations....tires/rims, driveshaft, axle then differential.
Do you think you know a better way?
they are giving you good service but you don't know enough about it to realize.
#154
#155
Hi everyone
I purchased a new 2014 Silverado crew-cab this past January with 16 miles on it.
drove truck to Birmingham (80miles) a couple of days later, truck shook like all get out.
took truck back to dealership the next day, they rotated tires and balanced them, still have the shaking. To make this short, drove truck for 3 months got oil changed tires rotated and balanced, truck seemed to not vibrate as much, a little over 2 1/2 months went in for service oil change and tire rotation and balance, truck now rides as smooth as the 08 I had. It runs up to 80 mph like floating on a cloud and no vibrating. I have the Goodyear 18 inch tires. Maybe the tires needed to wear in a little to get the smooth ride.
#157
gotohatteras In my situation with the vibration, I believe it was as Tech2 had said a couple of months ago, tire stiffness. I had my tires rotated and balanced three times and the vibration lessen each time. Now I have a pretty smooth ride.
It is close to my next oil change and tire rotation and I wonder if the rotation will affect the ride or maybe improve a little bit more. I do believe that the tires breaking in makes some difference in the ride.
#159
What is tire break in ??? They
either roll smooth or not, from the
first revolution. Its possible to get
tires balanced on an uncalibrated machine,
and the next time on a calibrated or
different machine, and the ride improves.
A tire thats out of round or that has a belt
problem, does not cure itself. Larry
#160
that is what I have read in technical documents. In some respect I want my new tires to pass rfb new or old.
