2022-2023 Silverado LED Upgrade Bulb Size Guide
Platinum Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Lighting upgrades are a top priority for many 2022-2023 Silverado owners looking to enhance their truck. Swapping out dull OEM halogen bulbs for vibrant LEDs dramatically transforms the Silverado's style while boosting safety on dark roads. The LED installation is straightforward as long as you properly match new bulbs to halogen light sizes. We've compiled a bulb size guide for you. Use our handy reference chart to find LED bulb replacements guaranteed to fit your pickup and illuminate the night.
OEM halogen bulb size:
Low Beam: H11
High Beam: H11
Front Turn Signal Light: 7440
Back Up Light: T15/921/912
License Plate Light: T10/168/2825
You can try Lasfit LED bulbs on your Silverado 1500. These lights are high-quality products tested by Lasfit, which can bring a brand new lighting experience for your Silverado 1500. I believe that once you try them, you will be impressed by their excellent performance.
p.s. These LED bulbs can only be installed as replacements for OEM halogen Silverado.
Low Beam & High Beam: Pro-CS-01L LED bulbs
For the new 2022-2023 Silverado models, both the high beam and low beam bulbs are H11. However, the common H11 bulbs on the market cannot be perfectly compatible with its headlight housing. Lasfit Pro-CS-01L were specially designed for 2022-2023 Chevy Silverado 1500 with stock H11 halogen bulbs. The custom-fit dust covers are built-in turbo cooling fan to work with LED bulbs for quick heat-dissipation and protect the LED bulbs from water and dust. Truly 50W/bulb, 5000LM/bulb. Plug and play installation. Definitely smart choice!
Front Turn Signal Light: T-7440A(amber) for WT/RST/LT/LTZ/High Country T-7443A-CK for Custom/Custom Trail Boss
3000K amber mode. Lasfit T-series LED bulbs are specially made to replace OEM halogen turn signal lights. Erorr free, no hyper flash. Besides, intelligent temperature control and play and play installation also designed for 2022-2023 Chevy Silverado 1500.
Please note that there are many trims available for the 2022-2023 Silverado, and it is important to select the appropriate LED bulb based on the trim. This information is already indicated on the product page, so please pay attention when making a purchase.
Back Up Light: T-T15(white)
3000LM/set, bright white or brilliant red. CANBUS support for error-free. Built-in intelligent temperature control system. 100% plug-and-play installation can be completed in about 5 minutes on most vehicles.
License Plate Light: L-T10(white)
800LM/set, 6000K pure white. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Non-polarity design, no need any modification, just for plug and play installation.
Real Review from Lasfit customers
Huge thanks to them for sharing their experience with great pictures!
Case:
2022 silverado trail boss custom
Very easy to install
I order front headlight reverse light and rear license plate lights as well. Huge difference especially at night
Good product——Arturo P Grandon
Low Beam: H11
High Beam: H11
Case:
LASFIT
Colorado
September 12th, 2023 8:45 PM
LASFIT
2014 - 2018 (GMT-K2)
August 23rd, 2023 8:42 PM
