350 distributor problem
Old Jan 28, 2013 | 7:14 PM
panfry350's Avatar
Default 350 distributor problem
I have a 84 chevy with a 350 I bought a new dist but not getting any fire to my plugs. I have power going to the coil and even changed out the cap and coil with one I knew that worked, but still not getting fire!!! Any ideas or help pls!!
Old Jan 28, 2013 | 9:15 PM
kevinkpk's Avatar
How are you checking for fire to the plugs? Since you've changed the cap, is the plug wires correct to firing order?
Old Jan 29, 2013 | 7:13 AM
Allan In NE's Avatar
Module or pickup coil.
Allan
Old Jan 29, 2013 | 4:58 PM
panfry350's Avatar
im checking fire by putting the plug in the wire and grounding it to the block and cranking over the engine to look for spark. and yes the firing order is correct. Allen are you meaning the coil inside the cap?
Alwaysdutch
Jul 22, 2013 10:22 PM
Peanut
May 16, 2011 1:26 AM
bigh
Sep 17, 2007 9:47 PM
454 dually
Aug 31, 2006 10:43 AM
