4.3 INJ. to 350 CARB ELECTRICAL HELP
We took a 4.3 inj. Engine installed a small block carb engine, in a 1997 chevy truck. Would like to use the dash. All the lighting works, some gauges work, until you turn the lights on, then everything goes to zero. Weve never got the gas gauge to work, looking for help.
The fuel gauge will operate off of one wire and the body will be the ground(obviously) check the ground wires from front to back and this will most likely be the problem (assuming the instrument cluster has the proper power wires hooked up). Good luck.
Hope it helps.
1997, 350, 43, 97, c1500, carb, carbed, carboration, carborator, carbureted, chevrolet, chevy, electrical, engine, rdailey88yahoocom, view
