Old Jul 22, 2015, 2:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission
Print Wikipost
4L80 transmission problems
Old Sep 1, 2018 | 10:56 AM
  #31
Mike Sester's Avatar
Default 4L80e transmission problems
Originally Posted by kennyplay
Hello. 2 things. There is a 2 second delay going from park or neutral to drive. And secondly, I'm having a hard shift from first to second.( when tow button on, there is NOT hard shift). Any ideas?? Thanks
I’m having the same issues in my 02 2500hd 6.0L
What did you come up with? Thanks in advance.
Old Jul 5, 2022 | 10:05 PM
  #32
ARTWRK's Avatar
Default 2003 silverado 2500hd 4l80e shifts down a gear or 2 ,Dash reads Transmission hot
New 4l80e gets to 150-160 readout says Transmission Hot then shifts down 1 or 2 gears and will not go back to overdrive.Is that a sensor issue or a fluid issue?
Old Jan 30, 2023 | 7:18 AM
  #33
udidwht's Avatar
Better late than never....
You'll have to drop the pan to fix the connector (new wire harness) easy job. Once fluid makes it's way into the connector you'll end with all sorts of shift/no shift issues. Also clean out the other end well with electrical contact cleaner. Also good idea to replace both the shift solenoids while you're in there and turn the force actuator up 1/2 turn.
JimmyD55
Mar 20, 2023 7:54 AM
boydchr
Jun 25, 2015 11:25 PM
ChevyRS6
Oct 9, 2014 7:42 AM
xtremedyme
Oct 21, 2008 12:06 PM
