Last edit by: IB Advertising
- Chevrolet Silverado 1999-2006 GMT800 5.3 L V8 vs. 5.7L V8 Engine Differences
Important information to help you understand your Silverado.
5.3L versus 5.7L V8 "Vortec" Engines
#91
Love those 5.3's
I have two suburbans, both with 5.3L. My 01 is 2wd with just under 400 miles and is still quiet and plenty powerful, even though it has been totalled twice and is yet again being rebuilt, the body not the motor. It only gets like 15 to maybe 20 mpg on the highway. My 03 sub is 4wd with the flexfuel motor. It gets, and this is no bull****, 28 mpg on the highway when I took it to Atlantic city. The 4wd has all but 300 miles and is super clean, not a drop of oil or grease anywhere under the hood. I recommend the 5.3L to anyone interested in asking about them. I love my subs and would only sell them for twice what they r worth. I noticed that when I put the avalanche 17 inch wheels on I get a little better mileage on the highway, but it'll use more in stop n go situations because they r heavier and take a little more fuel to move them.
#93
I have over 300000 miles on my 2000 Silverado RWD and it still runs great, replace front wheel bearing, water pump, spark plugs and wires. The only complaint I have is I have a bad shaking in the steering wheel around 60-65 MPH and it’s not every time. I have new tires and alinement but the vibration keeps popping up. Love the truck burns no oil, Trans shifts smoothly.
#94
New User
Awaiting E-mail Confirmation
Shaking
#95
New User
#96
Oh im sure the 5.3/327 is different now just like the 5.7/350 is different now. They are just engines that have been improved on. For one the hp now from a stock barebone 5.3 and 5.7 which is standard in all trucks there is no upgrade from the factory other than motor size. Which has much more hp than a stock barebone 327 and 350 of yesteryear. Back then you could get a stage one / stage 2 upgrade for motors or what ever each car make called them.What im saying is the 5.3 is not a new motor its been around a very long time and only improved over the years same as the 5.7. Now the 6 liter is not as old its like a 360ci. I trust something that has been around alot longer and just improved apon. With only 84000 miles on your truck if you treat it well you should have it for a very long time.
#97
Miles on my 99 Chevy 1500 5.3l stock
We all know and love the venerable Chevrolet 'small block' V8 engine that has been under the hood of many different GM cars and trucks - as well as being offered in various displacements from 265 to 400 cubic inches throughout the past five decades.
The best-known and most-beloved has to be the "350" or 5.7-liter version; especially with Chevrolet and GMC trucks. They are powerful, tough, reliable and it is relatively easy to "soup up" or increase their performance.
Now, at least with full-size Silverado & Sierra trucks, the times have changed and GM replaced the 5.7L with the newer 5.3L back in 2001 or so. I own a (purchased used) 2004 Silverado with the 5.3L and have about 84,000 miles on it. It runs strong, doesn't burn oil and has the low-end grunt for which the Chevy small block is famous.
The 5.7L and 5.3L are both OHV engines, two valves per cylinder and use timing chains rather than belts (Yes!). Aside from what appears to be a coil-on-plug (hence, the short wires), are there any other major differences? Are they still made with both two-bolt and four-bolt main blocks? Is it true they now are using aluminum cylinder heads rather than cast iron? Are they similar on the inside of the engine?
Does the 5.3L have the longevity of the venerable 5.7L? I have a friend with an '02 5.3L and he is approaching 150,000 miles with it - and with no engine trouble at all. Sounds like the old 350 to me!!
I take good care of my vehicles and use Mobil-1 synthetic oil; which I change every 3,000 to 3,500 miles whether it needs it or not. I also change the oil filter every time - and intend to do so as long as I have this truck.
Can I realistically expect 250k from my 2004 without an engine or tranny rebuild? I drive about 70 percent highway and 30 percent city and my engine has about 3,200 hours on it so far (again, I bought it used last February with 74,000 miles). I don't drive like an old man, but don't beat on it either.
I have had a "BG" fuel-injection service done, a DexCool radiator flush; as well as a "BG" transmission flush back at 76,000 miles. At 90k, it is going to get a power steering fluid flush done (again - last done at 40k) and the rear differential will be serviced. I am also considering new shock absorbers and a wheel alignment when I get the next set of tires installed. Once I hit 100k, I am going to have the sparkplugs replaced - as recommended by Mr. Goodwrench himself.
Anyone here have more than 150k on the 5.3L engine? Any problems? I have always been a "Ford" guy (hey, I admit it) and still love the Mustang and their Super Duty trucks - although they are WAY TOO EXPENSIVE; but I like my Chebby and plan on keeping it for a long time (since it will soon be paid off).
I appreciate any advice or input! Thank you so much!!
P.S. It is 2wd Silverado LS 1500, although it is shod with 4x4 rims (17-inchers) that a previous owner must have installed.
I have stock 99 1500 almost 300k just now getting a tick noise replaced tranny once not chevys fault though.!
#98
Difference
Wouldn't going from a 5.3L to a 5.7L be a step 'backwards' for you? The 5.3 is a more modern design, has the "coil on plug" ignition system (rather than distributor) and develops more power per cubic inch. I think there might be some internal engine design changes, but I am not sure about that.
Either way, though, it is still a small-block Chevy and both engines should serve you well. :-)
#99
2007 Suburban 5.3L with 294,000 miles. Wife broke the forward sprag assembly in the trans at 202,000 miles while panic shifting from reverse to drive while still moving backwards then slammed on the gas. I rebuilt it and everything inside was well withing spec. I'd say 500,000 miles + on the 4L60e should be no problem with regular maintenance. It started eating lots of oil due to AFM but a couple cylinder soaks, afm shield and new valve cover mostly took care of that. Still burns some but nothing like before.
