'89 C1500 Clutch HELP
Ok, so I have the tpical symptom of a clutch with no pressure. We have replaced the master cylinder (twice), the slave cylinder, and even the flex line... The push rod in the slave cylinder is NOT moving and we are bleeding it by the book for both the master and slave cylinders. After we bleed the master, we move to the slave and we just aren't getting any pressure to it and the push rod is NOT moving.
My grandpa has beend a mechanic for 60+ years and he is at a loss... As he would say, this is the second time he has been wrong, and the first was when he thought he was wrong. I need some major help because this is the only vehicle I have to go back and forth to college and I dont have an option to buy anything else.
clutch prob
I have an 87 and I had the same trouble bleeding my clutch, by the book got me NO pedal no Matter what I did. Then someone told me to use a Vac/pressure pump to force fluid through the bleeder and out the resivoir. Apparently what happens is on the master there the rubber hose attaches to the plastic nipple, air bubbles get trapped in there and won't go down, but forcing fluid up through solves the problem, worked for me! well, good luck and hope this helps.
I had the ame problem with mmine when I replaced my clutch. I bled it and bled it. Just keep bleeding it! Drive it then bleed it then drive it then bleed it. If there is no leaks you will just have to keep bleeding it. And remember when bleeding it to keep constant pressure on the pedal. And you should only have to bleed it at the valve on the slave cylinder. Also make sure the slave cylinder rod is hitting the clutch fork!
Are there any leaks? If there are no leaks and you have bled it the only other thing would be a bad slave cylinder try taking it back to the parts store and telling them it does not work. I mean no leaks and it is bled what else could it be?
I wish I could do that, I wish I could try bleeding it like dmann suggested, but my grandpa left my mother and I without a warning.... Withh all three of our vehicles disabled.
I had a mechanic come out, fixed the pressure problem... Still won't get into gear, so it was the clutch disk in the first place, like I told my grandpa, so all of this was useless! Thanks for yalls help, now I get to try to find whose name the clutch was bought under.....
pdrayton
10
May 5th, 2024 2:27 PM
Dhmarkjr2
September 29th, 2021 6:49 PM
Andyg138
February 17th, 2018 5:03 PM
tangsoodn
November 26th, 2010 11:39 PM
