97 1500 350 mods
97 1500 350 mods
I just got a stock 97 1500 with a vortec 350, and wanted to pUT a true dual exhaust from the headers back, but shopping is a little daunting, was looking for some advice. Also what's the best things to do for power gains?
If I am correct then your truck has the fuel tank located inside the frame rail right in front of the drivers wheel. That location of the the tank will present problems when you are running the exhaust system on the drivers side.
On my 95 the exhaust manifold had a 2.5" outlet going into a 2" Y-pipe, then the cat. I installed a Magnaflow y-pipe that had 2.5" inlets and a 3" outlet behind a set of stainless mid length headers to help the exhaust flow better.
As far as the engine mods to get more power it all depends on how much money you want to throw at it. You can get cams, heads, injectors, intake and have your puter reprogrammed to increase the horsepower just remember the more horses you want the more money you spend.
You might be able to run a set of block hugger headers the come out behind the front and run them along the outside of the frame.
A cold air intake would dress up the engine bay nicely.
Wills.WindowsAndWheels
September 10th, 2014 5:49 PM
reemusk
October 18th, 2007 7:27 AM
mcastleberg
17
January 8th, 2007 10:59 PM
