97 pickup replacing clutch on 5spd
i have a 97 chevy with the 5 spd manual and im replacing the clutch in it, im replacing the clutch and the throwout bearing, is there anything i should replace because i dont plan on redoing it and i want it done right and last for a long time, any suggestions on what i should do to make it guaranteed good to go?
use NEW set, clutch disc, pressure plate, throw-out bearing, and if needed, the pilot bushing. also, have the flywheel turned, or replaced if needed, even if it looks good. flush out the hydraulic part of system as well, fill with new fluid.
spaulmiller
October 7th, 2009 12:01 PM
Hammer81
June 16th, 2009 2:12 PM
