98 Z71 silverado transmission
all seems to be well, except it won't downshift when you stomp the gas pedal, the engine revs high but that is it. Is this a linkage adjustment problem, speed sensor problem, or what? No service engine light, or anything. I would never have known anything was wrong except for starting to pass in a hurry and it not downshifting into overdrive.
Changed fluid and filter with no help there.
Any ideas????
Any ideas????
Last edited by hoov; October 9th, 2011 at 5:58 PM. Reason: Tried changing oil and filter-no help
I had the same issue on same model year...I have the 5.7Vortec engine.....mine was a faulty fuel pump, which is located in the tank. Is your fuel pump seem louder than usual? Mine got really loud, I could hear it inside the cab at an idle when I started getting the "no downshift" problems.
Good luck
Good luck
Good luck
Good luck
1998 Silverado stays in 3rd won't shift to overdrive would it be the speed sensor? if so where is it located? This is a used trans that replaced the original 1998 4l65e.
It seems like first and second is the same and third works but in overdrive it seems like still in third gear.
Last edited by sonnyfresh@sbcglobal.net; June 26th, 2012 at 2:42 PM. Reason: not enough information
Coravir
October 26th, 2019 3:28 PM
Allstar6803
December 19th, 2013 8:19 PM
jgray152
February 19th, 2012 11:12 AM
usahoe18
March 1st, 2008 6:35 PM
