99 Silverado Z71 random low speed brake failure
#11
Not fluid getting to right front caliper
I have a problem with very little brake fluid reaching right front caliper.The line is clear,is not showing any codes in computer.We pulled the rubber hose at the hard line so this isn't the problem.The fluid is getting to the other three corners fine. Any suggestions?This is on a 1997 1500 W/T.The truck has ABS.
#14
I had the problem when tight turning slowly into parking places. $500 worth of brake work did not fix it. It was the front left (Driver Side) hub/bearing assembly (Chevy Silverado, 5.3L Vortec, Z-71 4x4 with 269,000 miles). Once replaced ABS worked fine (Note the new hub/bearing assembly had a new sensor already installed on it). Thanks for all the help on these forums. They are better than calling a mechanic or taking it to a dealership.
xbigblue
September 15th, 2019 8:33 AM
BayAreaChevyGuy
November 22nd, 2010 7:15 PM
tsduke
October 21st, 2009 9:52 AM
EvilEye
September 29th, 2009 6:48 PM
zee28
September 13th, 2007 9:32 AM
