Abs
Abs
I know this has been discussed before, ABS and Brake light comes on intermittently, can stop engine ,restart ,lights go off ,Grounds on chassis reworked ,Will bleeding the system and putting fresh brake fluid help?
Maybe, maybe not. What you're proposing is like taking a vitamin pill for some abdominal pain. You may want to take it in for diagnosis when it happens and don't turn the engine off until the service advisor takes a look at it.
Probally so I ,it may goe days and not do this,Braking is ok no problems there just really annoying ,especially after just spending 1500.00 for frnt and rear seals,along with transfer seal and strut,abs was doing this before the seal replacement
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I agree with EinST. That may solve the issue, and only temporarily if you do not know what is causing the issue. I would suggest getting it diagnosed and see what the best options are for you.
Breanne
Chevrolet Customer Service
Breanne
