ABS light please help
Hey guys. I have an 04 z71 with 80,000 on it and i have been hearing some noise coming from the front end, mainly when I turn right it squeaked a little like the breaks needed replaced (checked them and they dont). Just today the ABS light came on. What can I do to fix this? Thanks
i bought one off ebay with a liftime for 100 bucks but at an auto parts store about 250 and that might take care of the light(probably not) but not the noise when he turns
Ok ill try the cleaning the sensors. The more I drive my truck the worse it gets. Found out that the noise is only coming from the driver side front wheel and it only happens when I turn right. Kinda sounds like a bearing that needs greased. Like a loud squeak.
2. grab tire at 6 and 12, bounce vigorously back and for. if you have any play, it's your hub bearing. donno about 98, on 2000 hub is $175 warranted from Schucks, and about 10 minutes job.
3. turn wheels this way or that way. can you duplicate the squeak? does it make noise only under load? if you have 2 WD model, it is likely your ball joint. if you have 4x4, it might be your driveaxle. also, tierod ends can make that noise. silly as it sounds, soak tierod ends and ball joint in water, on the knuckles, and see if noise goes away. also, try greasing ball joint and tierod end with grease gun via zerts.
you can always spend $200 on a hub later, if this worked.
kaptain howdie
December 16th, 2014 8:20 PM
Deteoni
March 28th, 2009 1:39 PM
