AC Problem
Old November 3rd, 2011 | 8:27 PM
Michael Harris's Avatar
New User
Awaiting E-mail Confirmation
Default AC Problem
My ac compressor wont turn on, nor my electric fans. Yesterday my ac compressor would flip on and off on and off, now it wont turn on at all. I tried to jump the low pressure switch which usually will tell you if the system is low on freon, which did not work. On suggestions would be greatly appreciated. 06 Silverado.
Old November 3rd, 2011 | 8:48 PM
kevinkpk's Avatar
You might try the connector to the compressor
Old November 3rd, 2011 | 11:57 PM
jwruss's Avatar
It is possible that the compressor clutch doesn't engage due to a weak coil. Has this problem on a 2001 Dodge and a 2001 GMC. Only solution is to replace clutch assembly or complete compressor.
Old November 4th, 2011 | 9:33 AM
kevinkpk's Avatar
Yes. To check it remove the plug, and check for constant voltage at the plug. If it is constant, AND the connection is good, then I suspect the clutch.
Rosariods
July 21st, 2011 8:13 PM
BayAreaChevyGuy
January 6th, 2011 2:27 AM
chenzo
March 21st, 2010 5:35 PM
99silver
February 2nd, 2008 4:14 PM
Yesi
October 8th, 2006 6:27 AM
Quick Reply: AC Problem
