ALL lights on at once
is there a way that i can drive with my high beams, day time running lights, low beams, and fog lights at the same time? im taking off to the desert and i want to light up the sand.
RE: ALL lights on at once
an easy way to get your highs and lows on at the same time is to get a kit from painless wiring for like $50. i had one on my old K5 and made a big difference. not sure about all of them on at the same time.
Or you could use a simple toggle switch to turn the lights on manually. All you have to do is ground a few wires at the BCM and the lights will be activated. Let me know if you want some wire colors\location
Here's a kit on eBay that appears to do just what you want.
http://cgi.ebay.com/ebaymotors/ws/eB...m=380044130886
Check your state laws. I rigged my truck so high and low beams would stay on when I switched to high beams. I had also added Hella fogs to my grille gaurd. I had them all on and was pulled over. The officier informed me only 4 front white lights were legal. Apparently thats the Texas law.
