axillary back up lights need some help and suggestions
i have an 08 chevy silverado LT extended cab i have a custum headache rack and i wanna put some auxiliary backup lights but i dont know were or how to do it. i have 3 inch gap between the cross members of the headache rack were i want to mount them but i dont know how to secure them properly. does any one have any suggestions as to how i can mount them, or which lights would be best. or on the other hand does any one have any ideas to other mounting locations that dont look tacky,
thanks
David
thanks
David
RE: back up lights need some help and suggestions
post a picture if you can or e-mail me so i can visualize were and how they Can be mounted otherwise it is hard ! steel or aluminum ?
Well heres some pics guys like i said their is a 3 inch vertical gap between the two top crossmembers were i want to mount them. Well i hate to admit it but i dont want to mess up the piant cause it cost a bit to paint the steel lol but i dont want to tack the lights on either way(in case service is needed on them ), i was thinkin maybe steel zip ties but i dont know if they will hold up against vibration ect. (as well as scratch the hell out of my paint) and i cant figure out how to bolt them on,self tapping screw?? but dont think i can fit a standard drill..well if yall have any suggestions as to how to mount them im all ears!!! or if any one knows of any alternative mounting points i'm open, like i said im lookin for a flush clean look. is their any points under the body? just i dont wanna mount them under the bumper yall know what i mean they look tacky just their under the bumper starrin at ya. and as far as lights im thinkin of some drivin lights from advaced auto parts. like i said im open to ideas and lookin for help, thanks for your time
[IMG]local://upfiles/18684/F7F0C4AA3B144DEBB971DEF860EC6DD1.jpg[/IMG]
rest of pics
[IMG]local://upfiles/18684/B18095F4211E4D11879DE1BF89AFFE5A.jpg[/IMG]
[IMG]local://upfiles/18684/55A0F1D297DC4F7286D4B3A5353769A7.jpg[/IMG]
seen the pic's and i pmed you back ,but also i know you did not want to mount them under the bumper ,but i mounted mine back their on my 2500 hd they look pretty good using existing holes in the bumper bracket's.used a 5 1/2 long x 1 1/4 3/16 strap steel with a 90 deg bend on one end ,and about a 45 deg on the other end and a 1" spacer to clear the bracket flange .i used two rubber housed utility 4 1/2 dia (tractor light's )just have them wired to a 7 wire trailer end plug ,pluged in to the factory 7 wire .i use them when i back up for snow plowintg .
Chevy_4_Life
May 23rd, 2015 9:03 AM
Ryan Brickel
May 25th, 2012 4:06 PM
jefferino
January 2nd, 2012 8:29 PM
