Bailing Wire vs. Pinion Shaft--WTF
This is insane. I was driving through a field and heard a strange sound. I got out and looked and noticed a whole bunch of bailing wire wrapped around the u joint and pinion shaft seal. After cutting away most of the wire i noticed that there was oil, just a little, dripping from the pinion shaft seal. Has anyone heard of this happening? Any ideas on how to fix this? Thanks a lot for your comments.
Except 8 <SUP>1</SUP> /2 in., 8 <SUP>7</SUP> /8in., 9 <SUP>1</SUP> /2 in. Chevrolet Ring Gears
8 <SUP>1</SUP> /2 in., 8 <SUP>7</SUP> /8 in., 9 <SUP>1</SUP> /2 in. Chevrolet Ring Gears
Special tool or their equivalents are recommended when performing this procedure.
- Raise and support the vehicle safely. Matchmark the driveshaft and the pinion flange.
- Disconnect the driveshaft from the rear differential. Position the driveshaft out of the way.
- Mark the position of the pinion flange, pinion shaft and nut. Using the proper flange removal tools, remove the pinion flange nut and washer.
- Remove the pinion flange. Position a drain pan under the assembly to catch any excess lubricant.
- Using a centerpunch, remove the seal from its mounting.
- Installation is the reverse of the removal procedure. Be sure to replace any lost lubricant. On all axles except those equipped with the Chevrolet 12 <SUP>1</SUP> /4 in. and the Rockwell 12 in. ring gears tighten the nut flush, then tighten to the original line scribed during disassembly. On the Chevrolet 12 <SUP>1</SUP> /4 in. torque the nut to 220 ft. lbs. and on the Rockwell 12 in. torque the nut to 350 ft. lbs.
- Raise the vehicle and support it safely.
- Disconnect the driveshaft from the axle.
- Position the propeller shaft to one side and tie it to the frame side rail.
- Measure the torque required to rotate the pinion and record the torque for later reference.
- Mark the position of the pinion flange, pinion shaft and nut. Count the number of exposed threads on the pinion stem, and record for later reference.
- Install Tool No. J-8614-11 on the pinion flange and remove the pinion flange self-locking washer faced nut. Position the tool on the flange so that the four notches are toward the flange. Save the scribed nut for reinstallation.
- Thread the pilot end of Tool J-8614-3 into the small O.D. end of Tool J-8614-2. Then with Tool J-8614-11 installed as in step 6, insert J-8614-2 into J-8614-11 and turn 45º to the locked position. Remove the flange.
- Using a suitable tool, pry the old seal out of the bore.
- To install, lubricate the cavity between the seal lips of the pinion flange oil seal with a lithium-base extreme pressure lubricant.
- Position the seal in the bore and place gauge plate J-22804-1 over the seal and against the seal flange. This tool assures proper seating of the seal.
- Using tool J-21057 or J-22388 for the 9 <SUP>1</SUP> /2 in. ring gear, to press the seal into the carrier bore until the gauge plate is flush with the carrier shoulder and seal flange. Turn the gauge plate 180º from the installed position; the seal must be square in the carrier bore to seal properly against the pinion flange.
- Pack the cavity between the ends of the pinion splines and pinion flange with a non-hardening sealer such as Permatex® Type A or equivalent prior to installing the washer and nut on the pinion.
- Using Tool J-8614-11, install the flange onto the pinion. Install the washer and nut and tighten the nut to the original position. Refer to the scribe nuts and number of threads recorded earlier.
- Measure the rotating torque of the pinion and compare with the torque recorded before removal. Tighten the pinion nut in additional small increments until the torque necessary to rotate the pinion exceeds the original figure by 1-5 inch lbs. Do not exceed the original torque by more than 5 inch lbs.
- Reattach the driveshaft, brake drums and wheels.
Thanks for the reply. I have attached a pic. pls check this out to make sure I know what Im talking about. thx
oh yeah...2 wheel drive 86 c10 305 half-ton auto transmission
barnesam
December 31st, 2022 2:34 PM
Simplejack
February 7th, 2012 7:28 PM
twofoot
September 2nd, 2008 4:05 PM
