blower motor flow help please
I have searched and searched and can't seem to find anything on this...
2000(old body style) chevy 2500 crew. My problem is that when my temp **** is turn all the way to the cold side good airflow comes out the vents in all positions(vent, floor, defrost, ext) but when I start turning the temp **** to the hot side I loose all vent flow. I have the dash tore apart, my heater blower motor works fine in all speeds, all the actuators, that I can find, are working. I pulled the heater core down far enough to visualize the door opening and closing when the temp **** is turned from hot to cold or vise versa. The blower motor stays the same speed just doesn't push any air out, but then again, if I turn the **** to the cool side then I have lots of flow. Any idea's? This is really starting to kick my butt! Nothing seems plugged, and I had the heater core and coolant system flushed and services a few months back.
Thanks for any help.
I posted something related to this in another thread about defrost door doesnt open. sounds like your problem too. you get air but no flow. blocked doors.
Scotto2323
August 20th, 2016 3:33 PM
chevywilly
November 26th, 2014 6:05 PM
