bose subwoofer?
I've got a 2004 silverado with a bose stereo. I was wondering if anyone knew if the 2004 models had a subwoofer in the console, before i tear it apart. If so, is it easy to replace?
I was wondering the same thing as i have a 2007 ??????It say's i have one but see no settings for it or any indication but have heard it is under center console but have not been able to confirm it yet,Maybe someone else here can shed some lght on the subject.
thanks for the help guys. would it be better to unhook the stock sub and put a new one in underneath my rear seator just leave it hooked up and run both subs, or is that possible? i'm kinda new to this car audio stuff.
You can buy a line output converter specificaly for the trucks with the bose system at www.logjamelectronics.com and then run a seperate amp and box under your rear seat. Thats what I did. Sounds the best. Box for our trucks can be purchased at www.subthump.com Great quality. Theres a thread about boxes in the audio section with some pictures of one of the members installs, check it out. You have to you a relativley shallow subwoofer though. Pioneer Premier makes a shallow mount and so does Rockford Fosgate. I went with the Fosgate Punch Stage 3 shallow mount DVC 4 ohm. You can get it at www.crutchfield.com Take note of the boxes mounting depth and get a subwoofer that will fit depth wise. Also take note of the boxes required air space, and find a woofer that works in that range. The boxes at subthump provide you with that information and most subwoofers will provide you with that under specifications.
Raptormann11
February 16th, 2013 6:16 PM
fakhir1234
February 27th, 2009 7:41 PM
