Last edit by: IB Advertising
Browse all: Powertrain Guides
- Chevrolet Silverado 2007-2013: How to Replace Electric Radiator Fan
A/C fan motor will not stop!
I have an 06' Silverado, the a/c, heater fan motor absolutely will not shut off unless I pull the fuse. It will run even without the key in the ignition. The only way to keep from running the battery dead is the pull the fuse under the hood. (40 amp). I tried swapping the fuse but it did not stop the fan motor. As soon as I plug the fuse in the fan motor starts running. Please help.
Welcome to the forum.
If I'm getting this right, the blower motor runs at full speed with the 40A blower fuse in, even with key off. The switch setting on the HVAC control module probably has no effect either. About the only way it can happen is if the blower motor relay is stuck on the 40A blower fused source. This relay is part of the blower motor resistor assembly which isn't too bad to replace on the Silverado.
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
pdrayton
10
May 5th, 2024 2:27 PM
pdrayton
May 29th, 2013 7:55 PM
SweetEmotion
April 27th, 2012 8:35 PM
Hapy1Luky2
September 23rd, 2011 10:51 PM
