chevy 3500 rear end swap
Old Oct 26, 2011 | 9:24 AM
mikew5432's Avatar
Question chevy 3500 rear end swap
wanting to change the rear end in my 95 c3500 dually to lower gears for fuel economy and still have towing capabilities of hauling our 35 ft 5th wheel camper, have the 454 engine w/4spd od tranny,crew cab, see they had some 3500 straight trucks with a 3:73 gears?ops,i'm soory, left out what gears i have now, it's the 4:10 w/posi rear end presently
Old Oct 26, 2011 | 2:46 PM
country_09's Avatar
Do you mean higher gears like a 3:23 or 3:42?
Old Oct 27, 2011 | 9:12 AM
mikew5432's Avatar
Default rear end swap
yes, but was thinking 3:73 gears as still need pulling power
Old Oct 28, 2011 | 11:06 AM
country_09's Avatar
what gears do you have now?
Old Oct 29, 2011 | 12:37 PM
mikew5432's Avatar
it has the 4:10 w/posi rear end presently
Old Nov 3, 2011 | 5:41 AM
recondrill's Avatar
easist solution is to find a replacement axle with the desired ratio at a salavage yard. I did this to a 88 Scotsdale I use to own. Replacing the internals to change the gear ratio requires a new pinion and ring gear, crutch sleeve and knowing how to use a dial-indicator plus knowing how much backlash should be in when putting new pieces in.
Old Nov 4, 2011 | 5:24 PM
mikew5432's Avatar
what i was wandering, have new junk yard in area with decent prices so guess i'll keep a eye out for one there. thank you for the responese. mike
earliebrd
Chevelle & El Camino
Mar 15, 2011 11:47 PM
TASpinney9110
Mar 15, 2011 5:54 PM
a.308man
Jan 27, 2011 4:54 PM
hydrodriver
Astro
Dec 11, 2010 8:52 AM
