Last edit by: IB Advertising
- Chevrolet Silverado: Why does My Transmission Clunk ?
Guide to diagnose trouble and recommended solutions.
Clunking Transmission
#11
My 06 1500 2WD with 18000 has this "clunking" noise when I come to a stop and as I begin to release any amount of pressure from thebrake, I get the clunking sound that seems like the rear end is being jolted out from under the truck. Am I experiencing the same problem that the TSB will fix?
#13
I just returned from a trip after have another transmission cooler added to the original auxiliary cooler. I also had the slip yoke removed and the old grease replaced with synthetic grease. I also had the transmission mount replaced. What else could be replaced in this drive train from the transmission back that might be causing this horrific noise... apparently I cannot put an allison transmission in a 2000 truck.....Does anyone know if this transmission swap is possible???????
#15
No, the slip yoke slides onto the splines that come out of the back of the transmission before the universal joints....I have also changed the transmission mount...
#16
Change the transfer case fluid. I did that yesterday and lubed the slip yoke and my klunk/creaky noise went away. If you have the autotrack transfer case make sure to get the autotrack2 fluid. It is a funky blue color.
James
James
ORIGINAL: matador
I hve something similar in a 4WD
#17
Is it easy to grease the slip yoke and if so, how? I have a 2000 silverado and it makes the clunk when I start and stop. I was told a nickle plated slip yoke would fix it but a dealership wants about $500 to do it and if I can just grease it, I'd rather do that.
#18
I just bought my 07 2500HD 4x4 6.0 and i noticed the exact same thing with it, havent towedmy trailer yet but when im on the brakesover bumps it sounds like a drive shaft clang.a big enouhg dip inthe road will make it slightly also.ill see what i come up with when i pull my car trailer next weeked, im trying to get some more miles onthe truckfirst.
might be a little rough on it pullin a trailer with only 120 miles.
dzonen
February 15th, 2007 11:13 AM
