Clutch issue
Old Jun 13, 2010 | 7:23 PM
itconsumes's Avatar
Default Clutch issue
I have a 2005 Silverado 2500HD 2WD with the NV 4500 5 speed. is there a reoccuring problem with the hydraulic clutch system? I lose pressure in my clutch constantly, occasionally I have to pump the clutch to build up enough pressure to shift and I have to refill the resevoir every couple days but i cant seem to find a leak anywhere. Obviously it can be extremely hard to shift. As my daily driver I'm hoping I can fix this somewhat inexpensively.
Thanks in Advance.
Old Jun 13, 2010 | 9:52 PM
LARIDERS's Avatar
well there must be a leak some where. thats why you are losing pressure. you could also have a bad master or slave on the clutch. you could put a big piece of cardboard under it and pump the clutch over and over or a long time till you find the drips then you can find the leak. I would do this with the truck not running in case the fluid in falling on somthing hot.
pdrayton
10
May 5, 2024 2:27 PM
Andyg138
Feb 17, 2018 5:03 PM
dcok4744
Oct 15, 2013 6:38 AM
4bywhut
Dec 26, 2010 12:16 PM
Bad_Luck_Brian
Mar 9, 2009 5:28 PM
