Notices
Code P0102
Old July 5th, 2021, 7:00 AM
mcivatte's Avatar
Default Code P0102
Hello and I hope everyone had a good 4th, so my problem I am having with my 99 Chevy Silverado 1500 with the 5.3 is I was having trouble accelerating, truck felt like it had lack of power. Pulled code and got the p0102 so I bought a new mass air flow sensor and hooked it up. Still getting the code even after resetting the battery. Now the truck has problems starting and when I do get the truck started it sounds like it wants to bog down and shut off until I unplug the sensor and it idles great, but once I hit the gas is when it has hesitation and as soon as I let my foot up it feels as If the truck lurches forward and is ready to go. I have looked everywhere for a vacuum leak, what else should I be looking at, spark plugs, fuel pump, could it be the wire harness itself for the sensor. If I could get pointed in the right direction that'll be great. Thanks in advance everyone.
Old July 5th, 2021, 9:23 AM
mcivatte's Avatar
Update... Just replaced the MAP sensor and I am now able to start the truck with the MAF sensor connected. But when I hit the gas the truck doesn't move and it slowly bogs down. With the sensor disconnected the truck still idles fine but hesitate upon acceleration.
Old July 5th, 2021, 11:27 AM
kevinkpk's Avatar
Do you have any leaks in the intake system?
Old July 5th, 2021, 1:08 PM
hanky's Avatar
Where did you purchase the MAF sensor?
You need to be careful/ fussy because imported crap is defective in the box.
Old July 5th, 2021, 2:15 PM
mcivatte's Avatar
from auto zone, it's a duralast.
Old July 5th, 2021, 2:20 PM
mcivatte's Avatar
I haven't found any leaks in the intake, I went around and made sure all bolts were snug. I have a 99 gmc 1500 for a parts truck. Was thinking of dropping the gas tank and switching the fuel pump.
Jonathan Jackson
September 16th, 2021 12:16 PM
Khux34
February 11th, 2020 4:57 PM
62catalinagreg
September 19th, 2013 2:00 PM
cam081409
14
April 27th, 2010 9:09 PM
exceler8
October 4th, 2009 8:44 AM
Quick Reply: Code P0102
