Cold weather idle issues '90 k1500 5.7L
My pickup has a new Holley TBI unit, and has had prior idling issues, which turned out to be the TPS. After replacement, the truck ran like a top until cold weather. Now it tends to idle either too high(900rpm) or too low(500rpm), depending on what mood she's in. It drives me nuts, because she's also a stick, and that can make take off tricky at times. This problem is also amplified when the defrost is on. Once the A/C compressor kicks in, the idle increases then levels off, as it should, but after the first cycle it just bogs the engine down to 500 rpm or sometimes kills it. I think it might be the IAC, but I was hoping for advice before I started just replacing stuff.
Thanks.
Thanks.
alxwilhelmi@aol.com
January 2nd, 2014 11:26 PM
Alisha9544
December 24th, 2011 8:24 AM
trbball44
November 23rd, 2006 1:15 PM
fredster
November 13th, 2006 3:14 PM
