Cold Weather Start Problems
I have a 1990 Chevy 2 WD 1500 with a 5.7 (350) engine. It does not start immediatly even in the summer but in the winter it takes almost 15 seconds of cranking to start. Now I do not just crank it until it starts, I do 2 - 3 second invtervals as I do not want to burn out the starter like last winter. I have new plug wires rotor and distributor cap. Checked the timing as well. I am using 10 30 motor oil and live in Denver Colorado where the winters can be cold but not as bad as the mid-west. Any thoughts would be very much appreciated.
RE: Cold Weather Start Problems
ZX1100F1 thanks for your reply
I just ran a can of 44K through the system with just under half a tank. No change. It cranks slow and takes 3 - 4 tries at about 3 - 4 seconds each to get the thing started in single to teen digit overnight temps. I am frustrated by this.
you say it cranks slowly.....possible battery problem? not cranking the motor fast enough to fire right away and floods the engine?
I would also look at the readings of your temp sensor. Usually when they go bad, they read either REALLY cold or REALLY hot. Eithr way, you would be getting a very rich condition, or a very lean condition, making morning starts difficult.
After 3 or 4 seconds of cranking, trying putting the gas pedal alll the way to the floor. This will cut off fuel and make a lean condition(helpfull if it is getting flooded).
shawnvw thanks for the info. Turned out the temp sensor was not reading properly so I changed it but this did not fix the problem. The battery as well as the alternator are less than a year old. Any other thoughts from any one would be helpful.
Oh, one more question? Does anyone know the sequence of events for the fuel pump. In other words I know it comes on for a few seconds when you turn the key but if this operation does not happen does it complete its circuit and come on after the car is started? The reason I ask is not sure if it is coming on in the beginning but it is obviously working after the truck is started or I would not be going any where.
Does the fuel pump run when you turn the key on? If it doesn't you might have a bad fuel pump relay. If the relay is bad it takes oil pressure to energize the fuel pump.
Thanks slc10844, that is most likely the problem. I only hear the pump come on rarely and only after it is already warmed up. I thought this was due to the amount of gas in my 30 gallong tank muffling the sound. I will check it out tomorrow when the weather is slightly about 18 degrees.
Colorado '06
drive for short distance, go in store, then wonder if my 06 Clorado will crank when I return.... I have changed the Tempature sensor and O2 sensor both codes from local auto parts... now I have a #1 Low Voltage reading... is it the regulator or the fuel pump? ... or both?
