Crank, no start.
Crank, no start.
OK my truck wont start. turns over and even starts for a second with starting fluid. When I turn the key its not getting the 2 second fuel prime its supposed to. Ive replaced fuel pump, filter, relay, oil pressure/fuel sending unit, ICM and ECM.
Ive found that on the orange wire going to ecm (blue connector), labeled battery feed is not getting power what could this be from and will someone help me track this wire. PLEASE HELP. Its not a big issue I know its just irritating.
if this wire is not powered, you will have a no start condition. the wire is fed power from the battery to a fusible link. check for power in and out of the fusible link. it feeds power to the fuel pump relay.
aric272727
February 3rd, 2008 9:57 AM
