DexCool Testing
Old Sep 26, 2007 | 3:41 PM
jcarter's Avatar
Default DexCool Testing
I recently flushed my radiator on my 03 Sivlerado 5.3 V8. Is there any way to test theCoolant and see if the correct water and dexcool mixture has been achieved? I flushed the system with water for quite some time and then added 2 gallons of Dexcool and toped off with water. I assume that some water was held in the block and I am ok, but being somwhat of a perfectionist I would like to test it if possible.
Old Sep 26, 2007 | 5:49 PM
ZX1100F1's Avatar
Default RE: DexCool Testing
In your owners manual it will list the Cooling System Capacity of your truck which should be 14.9 quarts.
If your cooling system capacity is almost 4 gallons (which it is) and you added 2 gallons of antifreeze and the rest water then you are OK as you want the concentration to be 50 to 67%.
There are test strips that you can get at the local parts house that will work with Dexcool if you really want to be certain.
Dave
gulfcoastjoe
Apr 28, 2008 2:37 PM
dh0765
Mar 7, 2007 10:38 PM
dh0765
Feb 17, 2007 12:20 AM
