DRL - Bulb Replacement
Old Jul 7, 2008 | 3:07 PM
NumbaKruncha's Avatar
Default DRL - Bulb Replacement
Hi All,
My first post. I have a 2005 2500HD Duramax. Love it - but hating the price of diesel!!
Anyway - need to replace the drivers side DRL bulb. Any tips on how?? I look behind the light and it's practically solid! I can't seem to get to the back of the light.
Thanks in adavacne for any help.
~Mike
Old Jul 7, 2008 | 3:49 PM
ehhget's Avatar
Default RE: DRL - Bulb Replacement
On mine I need to remove the headlight above to get down behind the DRL and there is a rubber panel there you can bend out. All you do is remove the two pins that hold the headlight assy in place and pull out, try that.
Old Jul 7, 2008 | 3:54 PM
Thanks.
Do Iremove the headlight assembly from the front of the headlight, or the rear?
Old Jul 7, 2008 | 4:10 PM
ehhget's Avatar
Should be on the top you will see two aluminum pins, you turn them out and pull them up out of the headlight assy and the entire assy pulls out forward.
Old Jul 7, 2008 | 4:53 PM
WOW - - that was so simple and logical thatI missed it!!
That was probably the easiest fix I've ever done.
Thank you - - I would have been scratching my head for hours wondering how the hell to get to the back of that assembly!!!!!!
Old Jul 7, 2008 | 11:14 PM
ehhget's Avatar
no problem
mpireone
Jun 12, 2015 2:15 PM
cams 98 silverado
Dec 24, 2008 1:09 AM
CRFrizzell
Mar 8, 2008 10:13 PM
steeler560
Nov 12, 2007 6:58 PM
