Electric Door Mirrors INOP. Door switch or mirrors?
Neither one of my mirrors work. I am hopeful that the switch is bad and the mirrors are OK.
Can I just yank the switch and check it with a MM for Voltage in and out of the switch? Or, is there a better way.
My mirrors also don't work anymore. I have them where I want them and that's the way it has been for years. I have heard that the motor in the mirrors go bad from rain and the weather, and if I knew how to remove the mirror so I can get to the motor, I would do it.
Can anyone answer this question?
Most times there on with glue or tape you can try a heat gun but its one of them parts easier to buy gm probably sells a set no fix I have ever seen
Best bet junk yard bring a 12v battery with ya and test before you buy
realbadchevy
August 5th, 2011 4:15 PM
mightyorion
August 15th, 2009 1:30 PM
wffokker
June 21st, 2009 3:30 PM
