Old July 22nd, 2015, 10:48 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
Emissions Control System 2008 Chevy Silverado 1500 5.3L Gas Engine
Old September 8th, 2012 | 8:59 AM
  #11
Richard Lowman's Avatar
Default my 2008.4.8 truck
2008 silverdo wt 4.6 engine..engine light came on...30,000 miles if the dealer does a diognostic and finds enissins bad..maybe a oxygen senor..its covered i think...but will the diogenostis be covered because it is eniniss related ?? thaks richard... btw..if it gives a reading ? is there something else going on in the engine that is not right ?
Old September 11th, 2012 | 1:15 PM
  #12
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Richard Lowman,
Would you please PM me the last 8-digits of your VIN, so I may look into this further for you?
I look forward to your reply.
Louis
GM Customer Service
Old November 22nd, 2015 | 2:14 PM
  #13
Rebecca's Avatar
Default Bad Cat. after emission recall repair
Our 2008 Chevy Silverado was at the dealer being repaired for AFM problems. 2nd time the truck has lost prime and the lifter failed. They replaced some lifters, cam, heads etc... While it was there they reprogrammed emission for 2015 recall. Picked the truck up knowing we had to bring it back because they didn't replace the loom covering the wires. Drove home fine but the next day it throw an emission code. After a diagnosis they called and said the Catalytic converter was bad.. The dealer said they wouldn't replace it. How should we proceed?? They reprogrammed emissions which caused the Cat to malfunction. If they aren't responsible I'd think GM would be... 2008 Chevy Silverado 1500 5.3 90,000 miles
ahearnm
March 19th, 2023 6:37 PM
GradyCheek
22
February 28th, 2018 7:21 PM
cenglade
April 10th, 2012 10:59 PM
BillL
April 26th, 2011 5:23 PM
surfandride
January 16th, 2011 10:05 PM
Quick Reply: Emissions Control System 2008 Chevy Silverado 1500 5.3L Gas Engine
