ENGINE STALLING!!!!!! HELP!!!
Old Nov 23, 2006 | 4:07 PM
mosiecki's Avatar
Default ENGINE STALLING!!!!!! HELP!!!
6.5L Diesel engine, 1995 Chevrolet Suburban . . . The engine stalls while driving, and it will restart right away. It may not stall again for hours, but then may stall every 5 or 10 minutes. It always restarts, but becomes a random problem. If you have any suggestions plese help, it is a CONSTANT pain!
P.S. The injection pump has been changed several times, and is now out of waranty. If you have any other repairs in mind, I'll try just about anything.
Thanks,
MOsiecki
Old Jan 5, 2007 | 7:55 PM
flywhiteguy2244's Avatar
Default RE: ENGINE STALLING!!!!!! HELP!!!
When was the last time the fuel filter was replaced? It could be clogged and now allowing fuel to get to the engine. check the fuel line from the tank to the engine to make sure there are no kinks or twists. also check all of your vacuum hoses and the EGR valve. You can get the valve cleaned but it will only work temporarily (2 or 3 months) so it would be betterto just buy a new one.I had the same problem with my truck and after replacing these two parts, the truck ran as good as new.
Old Mar 24, 2011 | 3:04 PM
anthony chev's Avatar
hello i have the same car and the same problem.
i have had to replace it with a manual fuel pump now what happens is it runs 10 secs how do i fix or what did you do thanx
Old Jun 28, 2011 | 6:07 PM
jowiliam's Avatar
Did you solve your problem? It is the same for me. please let me know if you found what was it. Tk's
proud_sierra_driver
May 21, 2009 1:00 AM
elie2wins
Mar 11, 2009 8:19 AM
buijon
Dec 15, 2006 6:07 PM
WRT111
Aug 27, 2006 9:33 PM
Spike44
Jan 21, 2005 11:58 AM
