engine temp. veries by about 30 degrees.
Hi,
I have a 1996 Dually Crew Cab with a 7.4 V8. The temp seams to be running high but doesn't over heat. It runs between about 200 to 230 degrees or a little higher if I'm sitting still. What is the normal running temp. and what do you think I need to do. The fluid level was a little low and added about a quart. When I stepped on the gas I did hear some noise in the heater under the passanger side floor. Can you give me some help?
Thanks,
Thanks,
RE: engine temp. veries by about 30 degrees.
I think you need a new thermostat...My 90 1500 and 02 2500hd both stay around 190-195...
Does the noise sound like water running through it?
cave76
December 13th, 2011 9:07 AM
mary900
March 22nd, 2008 3:45 PM
pookster71
December 27th, 2007 11:36 AM
carlsndfw
January 29th, 2007 10:57 AM
