fouled plugs
fouled plugs
hello guys. i am having to replace two plugs (one each side against firewall) every three or four months. they are not oil fouled, they look more like overheating fouled.it is only those two. can it be the egr valve?. only weird thing i notice is a strong gasoline smell every once in a while. any ideas?. thanks
forgot. it is a 94 w/t 4.3L,147,000 miles.
according to the chart i am, in the overheating, deposits,and breakage. all of them related to overheating.is it too hot of a spark ? because the truck itself is not overheating.one of the "reasons" on that chart is too hot to too cool to fast. thats why i ask if it could be a dysfunctional egr valve. when you talk about overheating related to spark plugs, you mean overheating engine or overheated spark combustion?. thanks
If you are running the correct plug for your engine, have you dropped the gas octane? If so, I'd think about a colder heat range plug. I'd go one range colder plug.
stevemaman
August 27th, 2012 5:20 PM
TylerWalker
12
April 22nd, 2008 10:37 AM
dbrog28301
Colorado
May 21st, 2007 9:48 PM
epekarik
July 14th, 2006 12:51 AM
