Front Diff Questions.
Old Aug 5, 2009 | 11:54 PM
suzuki-guy's Avatar
Question Front Diff Questions.
When I replaced my front right cv axle I noticed when I spin the axle shaft(that the cv halfshaft bolts to on the front pig) had a rough spin to it. Now when I wiggle my cvhalshaft it has some play in it. Is it normal to have some play? I am also unable to figure out what is causing a growling noise that appears only when I turn right. Could this be the front axle bearings causing this noise? How hard re these to replace? Thanks guys.
Old Aug 6, 2009 | 8:58 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Zuk,
as long as the axle was not engaged, the differential would not be turning.
That half shaft is removed be 5 bolts on the differential and 2 bolts on a hanger, the axle is held inside by a ring clip that may need replacing, this would explain the play you described. It is fairly easy to do and I think I have a exploded view at home that I had my local dealer print out for me.
logeelandzr2
Jan 12, 2016 8:17 AM
bassestkkm
May 5, 2012 5:54 PM
petrou
Apr 22, 2008 10:18 AM
2004urb
Oct 21, 2007 2:23 PM
Faith_plus_1
Mar 2, 2007 3:17 PM
