gauge cluster question
gauge cluster question [/align][/align]looking at 1998 chevy pickup
When you turn ingition switch to on position.
brake light, seat belt light and other lights come on dash.
But I did not see a engine service light come on, is it also suspose to come on at this time with other dash lights?
Then they go out when truck is started.
I just want to make sure engine service light i's working properly.
Sincerely,[/align]
Sincerely,[/align]
ORIGINAL: wellmax
Sincerely,[/align]
Sincerely,[/align]
I've seen older vehicles where that lite wouldn't work, I hooked a scanner to the data link connector, just to see if I could communicate with the computer.
Thanks guys,
So the " service engine soon" lite should come on when ignition is turned to the on position.
Will check it out in this truck.
Thanks again,
Thanks again,
The SES light should go thru what is a called a "bulb check" which turns the light on briefly after a key cycle so you can tell if you have a burned out warning lamp.
I have seen unscruplous people remove the bulb and resell the vehicle rather than make a necessary repair.
thanks zx1100f1
that is what i am concerned about. I want to know all systems are go and the lite did not come on.
Will pass on this truck.
thanks,
thanks,
Jonew
April 10th, 2013 6:48 PM
