Old Jul 24, 2015, 6:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Engine and Powertrain
Print Wikipost
GM Dexcool Anti-Freeze/Coolant
Old Mar 8, 2010 | 7:18 PM
  #11
Bobby's Avatar
I just flushed and changed my 2001 Silverado to Prestone. 112,000 mi and the heater wasn't working properly after that works like a champ!
Old Mar 8, 2010 | 7:48 PM
  #12
JK23112's Avatar
Default Dexcool v Prestone
Bobby,
How did you get all of the 'orange' stuff out? When you put in the Prestone coolant, does it show yellow/green in the reservoir - or is it still orange?
How many gallons did it take? Did you buy the pre-mixed stuff or did you add water?
I'l flush mine out soon - within a few weeks, I suppose; and I am leaning towards keeping Dexcool in my '04 Silverado - but will probably change it every other year (just to be safe).
Old Mar 9, 2010 | 6:17 AM
  #13
Bobby's Avatar
I drained the radiator put in one bottle of Prestone Flush and ran 10 miin. after it reached normal operating temp. Drained it and repeated procedure. After that I drained and put in a bottle of Prestone cleaner and ran it for a total of 3 hrs. I then drained it and filled with just water and ran it about 10 mins. drained and repeated that. Then filled with 70 - 30 mix and it's good to go. Yes it is green now.
flush twice
clean once
flush plain water twice
Then fill with proper mix it took about 3 gals. total I went 2 antifreez, one water probably overkill for my climate, 50 - 50 is probably ok unless you are in a cold climate
It took me a good portion of a Sat. afternoon to do the flush & clean then ater driving around the next afternoon to finish up.
I am not a mechanic and money is tight right now so I have begun doing as much of my own maint. as I can. Local shops wanted around $150-$200 to do what I did and I spent less than $50 on everything and Prestone even had a rebate on one jug of antifreez so net cost is about $30.I aso changed the oil in 3 of my vehicles while doing this saved about another $50 over what I have been spending plus there is a lot of satisfaction in doing it yourself.
Old Mar 9, 2010 | 7:36 AM
  #14
tsduke's Avatar
flush twice
clean once
$150-200 seems high for a coolant flush.
Old Mar 9, 2010 | 10:00 PM
  #15
Bobby's Avatar
Have you priced one lately? That was the range in looking online, besides I know how much time I had in mine and what supplies cost even with some sort of machine to do it I don't think that is an unreasonable amount.
Just my thoughts
Old Mar 9, 2010 | 10:14 PM
  #16
992door's Avatar
did you cut your heat on when you flushed it? and you are not that far from me only about an hour I am in winterville just outside of greenville
  #17
tsduke's Avatar
Just my thoughts
The Chevy service shop here threw me a number last week. I could have sworn it was just over $100.
Old Mar 10, 2010 | 6:35 AM
  #18
Bobby's Avatar
Yes Cameron I did that was the main reason I did it the heater wasn't heating up as well as it should, and Iwanted to make sure the core got a good flushing also.
TS you may have gotten a price that low but I can't see how anyone could do what I did and make any money at a price like that. I spent $44 on antifreeze flush and cleaner plus a total of about 3 hrs in labor. The way I did it I know it was a thorough flush.
Old Mar 10, 2010 | 6:40 AM
  #19
tsduke's Avatar
Just to clairify. I'm not arguing the cost at all. Was just surprised to hear it was that high is all.
Old Mar 10, 2010 | 7:42 AM
  #20
tsduke's Avatar
Okay, it was bugging me so I called the Chevy garage to ask the price. $109.95 for Dexcool flush in the Silverado.
