Grinding and rubbing while turning to decline or slanted surface
This is driving me crazy because I've spent thousands on trying to find a solution. I've replaced my ball joints, hub bearings, driver side cv axle, and other things that I don't think are related to the problem. But I still have this grinding noise as I turn on to a declined surface and I can actually feel my truck slowing down. I don't think it happens on an incline. I've googled a solution forever but nobody seems to have the same problem. So I just joined this forum in hope that someone can help me find an answer before I spend any more money.
Welcome to the forum...
What year and model... does it do it all the time or just doing when its cold out... at 40F and lower my front sway bar bushings make a lot of scrunching noise....
in2pro. It's an 08 silverado 1500. And I live in Hawaii so it doesn't get very cold, even in the winter the lowest temp is 60.
Might want to check the brake calipers and bolts, the calipers need to slide some what easily on the pins...
