Hard starting 2001 2500HD 6.0
When i go to start it most of the time on the first key turn it will just roll over. Most of the time on the second cranking it will start. I changed the fuel pressure regulater, witch i thought was the problem but still does it, any other sugesstions?
Fuel Pump is going south..My 2000 Chevy 4x4 with the 5.3 did this for about 8 months. Then one morning,would not start at all. Like badboy said.IF its below 50 lbs. its going out. Best of Luck.
I have a Chevy Silverado 2002, Isuzu 8GF1XS. In trying to turn shipping no evidence of electrical signal to the injectors. I can do to resolve this?..Please Help me...to readramirez@gmail.com
The fuel is bleeding back into the tank when sitting. If it runs well after starting then the check valve in the fuel pump assy. is bad. I added an inline check valve and that solved my problem.
nissan4x4
10
January 17th, 2021 10:17 AM
fastfirebird
16
September 24th, 2009 6:41 AM
