HELP! Stabilitrack off. P0308 misfire
New User
Awaiting E-mail Confirmation
Hi i have a full size 2008 silverado with the 5.3l engine. I have had this problem for a little while. While I idle the truck for like 2 or 3 mins the message on the dash says stabilitrack off, service stabilitrack, stuff like that. Then CEL comes on. Sometimes the CEL flashes. Runs rough for a while then when i get goin at like say 40 or 50 mph for a ways the service stabilitrack message goes away but the CEl is still on, and seems to run fine. I have a superchip and the diagnostic comes with up with a code P0308 misfire cylander 8. IV changed the pluggs and wires and swapped the coils. What do you guys think?
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
New User
Could be intake manifold gasket. Usually manifold gasket symptom is rough idle/low rpm and runs good higher up and under load. Depending on how bad it is.
Do a compression check first on cyl 6 and 8 to see any difference. Pull fuel pump and ign relays or fuses.
You can bring it to a shop and have them run a fuel injector balance test. I don't believe this is 100% effective to determine if the injector is bad but its a good flow test.
NJ_Tahoe
September 26th, 2013 9:54 AM
mutineer
April 22nd, 2012 7:19 AM
xastrosrulex
June 9th, 2011 12:41 PM
