how to check a maf
Hey, By mistake I spliced into the signal wire of maf, with a potentiometer, I was suppose to use the map signal wire, But any how I now have a problem with idling, It cranks fine but the rpms then drops up and down until it gets to about 500rpm, And at stop lights its drops lower, but it hasn't cutoff. Is there away to check and see if I have damaged the sensor. thanks
phxtravis
May 16, 2007 10:13 AM
