Last edit by: IB Advertising
Browse all: Exterior
- Chevrolet Silverado 1999-2006 GMT800 Bed liner modifications and How to install drop-in bed liner
Overview of popular modifications to customize your Silverado and step by step instructions for do-it-yourself repairs
how do i improve mileage on an 8.1?
i did not get this truck for it's economy but to use it for what it is. but at the same time i found myself driving on the highway alot. i am getting almost 15 MPG now so i don't think i can do much better than that. is there anything i can do to improve on that other than a gear change? i have 3.73 now. i was told that the aftermarket cold air intakes don't improve anything on these trucks because the factory filter and plumbing will flow more air than the throttle body will. just looking for opinions. thanks.
Cold air intakes on any vehicle will not help increase gas mileage.
it lets more air in creating a bigger explosion which uses up more gas giving you more power, not better mpg.
It's designed to decrease the temperature of the air entering a vehicle to take full advantage of the engine's power.
Colder, denser air gives an engine the extra amount of power that it needs to perform at it's maximum potential.
8.1 seems pretty excessive to me.
What do you tow? houses? hahaha
Is it an automatic or manual?
1-You could get a highway gear installed and cruise at lower rpm's.
2-you could install a turbocharger. A turbo atomizes the air going in so that when it mixes with the
fuel there is not as much unburned fuel thus giving you better mpg. This well help mostly while just
cruising on the freeway. Not recommended if you have a lead foot like me cuz it could also greatly
decrease your gas mileage if you are constantly calling for a turbo boost.
3-Get a Tenneau cover. The bed creates a massive drag on the truck. Getting a bed cover will make
it more streemline and aerodynamic decreasing the wind resistance.
4-Use Chevron gas. Chevron contains the addative Techron that helps the fuel burn better and more
efficiently geting you increased gas mileage.
5-Use Chevron oil. Yes, even chevron's oil contains additives that have proven to help increase gas
mileage using a superior lubrication addaitive that helps your mechanical parts move more freely.
It is also inexpensive and available everywhere. I use 20w50 chevron oil and will never switch.
6-You could get your EPROM tuned to a more fuel conservative mode.
Hi jensonracing77,
Welcome to the Chevy Forums.
A set of new gears out the door(had it done for improved mileage) is about 2000$, with the bearings. Be sure to have the Parameters in your PCM reprogrammed so your speedometer and ABS alarms don't go nutz. You can save 2.5-3.5 MPG with a decent gear change. In your case, I wouldn't recommend going to 342s, if you already have 373s you'll want 323s to see a marked and noticeable improvement in gas mileage. You will see an obvious drop in your hard accelerations, specifically at takeoff, however.
The other major gas saver is a bed cover. An aerodynamic fiberglass cap or tonneau cover (@300$ to 1400$, depending on what get) will save you another @ 2.5-3.5 MPG.
These were the two major gas savers for my 2500HD CCLB, but to spend this kind of money for such radical changes, you have to keep the vehicle for many years to get a payback on your investment. Gas isn't very likely to go down in price very much very soon in all likelihood. I only have a 6.0L engine, so it's hard to claim with any real accuracy that you'll get better or worse mileage from either of these mods.
mille racer 69, i dont know how you say a cold air filter doesnt give better milage, it does, maybe not the 8.1 because like he said the stock one is good on that, it could however benifit from a K&N air filter
sythetics in the diffs and engine give better millage especially with such a huge engine
a gear changewill help, but ill bet u tow with your truck so i would go with 3:43 gears
with this i would go with an aftermarket tuner rather than a set tune, so that you can increase the power when you want and put it in economy when you want as well
if you tow a 5th wheel a tonnou cover isnt the option, but if towing with a hitch it will be a good one to get (there are also velcro fabric covers that roll up and wont take up a 6x8 plot in your yard when off the truck)
also platnum plugs goes without saying
if you dont have a small plastic air dam under the front bumper, im sure there are some in the aftermarket this will give you a small improvement, but all of these together could net a very significant improvement. i hope this helps
thanks to everyone for the ideas.
The bottom line is that other the a gear change the milage with an 8.1 is what it is..Headers, exhaust cat back or not & cold air intakes don't give fuel milage or for that matter even horse power...I have my 8.1 in a 4x4 3500 conversion van & I love my beast, milage or not.. Best of luck Dan
At the end of the day, fuel economy is a battle generally won by inches, not by miles.
A good tune up, really good heavy duty truck gas shocks, proper tire inflation,(I only go a couple pounds over normal,no more than 10% overall), a good wash and wax job, it all adds up.
Many times it means the difference between
big sweat or no sweat when you have 1/4 tank of gas left.
