How do I put in aftermarket head unit in a 93 silverado?
I am confused. There is a stereo/factory amp down by the accelerator pedal. There is a bracket with 3 bolts holding it in place. It has 2 small harnesses connecting to it on the bottom, and on top, there is a bigger wiring harness and a place where the antenna plugs in.
I tore apart my dash board tp get the radio out and discovered that the factory radio has no harness on the back and the wires just go straight into the radio. This must mean that the radio on the dash is just a "remote" and it is plugged in down under by the accelerator where that stereo/factory amp is at?
I want to get an aftermarket head unit and I am also confused on the wiring part. I already bought a dash kit adapter to fit the hole where the cassette player is at, and I bought the wiring harness. I havent bothered to see if there is instructions... could you tell me the wiring process? I have some sort of idea but I am not sure.
The wires should unplug from the back of the radio, that is where the adapter would hook to then from there it would go the the amp then out to the speakers. The wire and colors are as followsCar Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
mightydog4805
April 14th, 2020 12:11 PM
chevytalk52
November 20th, 2012 1:23 PM
brasskey
May 28th, 2007 10:47 PM
